no power
Old Feb 26, 2007 | 11:11 PM
amitchell's Avatar
amitchell
no power
Hey guys my 97 f350 will barly make it out of the driveway when it is cold. I can have the pedal to the metal and it is lucky to reach 10 mph. Only happens if i do not plug it up or let it sit and warm up. Any ideas?
Old Feb 26, 2007 | 11:19 PM
ForemanES's Avatar
ForemanES
Hey welcome to FTE
The truck is fine when it warms up? Does it run rough or smoke? Any hissing sound from the turbo?
Old Feb 27, 2007 | 08:02 PM
amitchell's Avatar
amitchell
Hey foremanes, truck is fine when warm and only smoke when it has been sitting for a week or so. Will have to listen for turbo but have not noticed it.
Old Feb 27, 2007 | 09:02 PM
96stroke's Avatar
96stroke
Check out some of the posts on EBPV (exhaust back pressure valve). That's one possible sourse that should be pretty easy to check and rule out.
Old Feb 28, 2007 | 04:48 PM
bkcowboss's Avatar
bkcowboss
amitchell when it is cold before you start it underneath your air intake just before your turbo you will find a wire plug there are wires running under your air intake behind your engine. Unplug this harness and see if the proble persists, if so you have an exhaust back pressure valve problem. I leave mine disconnected. Whatever the resolution is remember to post the answer so that others will know if it worked.
Old Mar 1, 2007 | 08:05 PM
amitchell's Avatar
amitchell
thanks bkcowboss i get the truck back tomorow definatly will give it a try.
Old Mar 18, 2007 | 09:01 PM
amitchell's Avatar
amitchell
Question
Finnally got truck back and i am looking for the ebpv to disconnect it. Does anyone have pics. Sorry i am new to working on diesels
Old Mar 18, 2007 | 09:36 PM
walt1968's Avatar
walt1968
Before I removed my stock airbox I just unplugged the sensor that is on the stock airbox (only one attached to it) That should do it for you.
Old Mar 19, 2007 | 12:40 AM
DAVID'S97F250HD's Avatar
DAVID'S97F250HD
Thats your air intake temp sensor in the air box.
Old Mar 19, 2007 | 05:28 AM
walt1968's Avatar
walt1968
You are correct. Worked like a charm.
