Rear axle seals
Old Feb 26, 2007 | 08:53 PM
Tom D's Avatar
Tom D
Rear axle seals
I replaced my rear axle seals about 4000 miles ago and I noticed the other day one is leaking. I was sure to install the bearing with the proper torque. Possibly the axle has a worn spot on it that prevents the seal from sealing properly. Do they make a shim that will move the seal to another spot on the axle? It is a 93 F250 with approx 167K on it. Thanks for the help. Tom
Old Mar 3, 2007 | 09:09 PM
dv_shane's Avatar
dv_shane
autozone has a bearing and seal kit that will fix that
