Rusty spring/shock mount
Old Feb 26, 2007 | 12:04 PM
fairlaniac's Avatar
fairlaniac
I notices tha tmy RF spring perch/shock mount is rusty as in flaky rust. There is a vertical rib where it looks like moisture and dirt may have gotten behind over the years. I'm sure if I keep the truck for more than 2 more years it will need replaced. Since I plan on keeping it until it rots into the ground I guess I'll be replacing the mount. Do you use bolts to put another back on instead of rivets? What did shops use if a truck came in say from an accident and the mount needed to be replaced? Most body shops I don't think have a riveter capable of riviting things back together? Anyone ever replace their shock/spring mount?
Thanks,
Old Feb 26, 2007 | 12:48 PM
gustang818's Avatar
gustang818
Bolts are typically used when replacing rivets.
Old Feb 26, 2007 | 01:01 PM
fbama73's Avatar
fbama73
Just be sure to get grade 8 bolts and you'll be fine.
Old Feb 27, 2007 | 12:29 PM
alz's Avatar
alz
There's also a clip that holds the brake hose on that bracket. I had to order them from the dealership and you may want to pick up a new hose as well.
hasteranger
13
Mar 25, 2014 05:14 AM
jimcar-9
13
Oct 17, 2013 12:29 AM
chrison600
Aug 25, 2012 05:16 PM
gmammakn
Jun 25, 2012 12:04 PM
sigtauenus
Nov 8, 2007 01:49 PM
