Ratio Change
Old Feb 25, 2007 | 10:06 PM
av226's Avatar
av226
Ratio Change
I own a '02 350 Pwr. St. I am considering changing my tire size from 265/75/16 to 285/75/16. What changes do I need to make in order to keep my 3.73 rear end ratio? Additionally, I am considering BFG AT's, Toyo M-55's, or Toyo AT's (in E range only). I pull a 7,000 lb gooseneck (unloaded). Does anyone have any experince with these tires?
Thanks in advance
Old Feb 25, 2007 | 10:13 PM
hosemandc's Avatar
hosemandc
I run 305's and have no issues with gearing and I dont think you will either with 285's. I have BFG AT's on now and I hate them but mostly because the tire dealer put c rated tires on my rig and I didnt realize it till a year later when I tried to put a 4000k camper on it and I coulnt air up the tires enough. I have new Toyo AT's E rated now waiting to go on this spring for towing season.
Old Feb 25, 2007 | 10:18 PM
av226's Avatar
av226
Thanks. What have you heaerd about the Toyo AT's, good tread life, traction, etc.? Would I need a leveling kit or lift kit to install 285's?
Old Feb 25, 2007 | 10:23 PM
hosemandc's Avatar
hosemandc
I don't buy anything till I read ans read about it. I hear they are great and I bought them however I havent tried them yet. I dont have a leveling kit and I run the 305 70 r 16 without rubbing with stock rims. Not sure about the 285's. My tires are suppose to be 33x12.50.
Old Feb 25, 2007 | 11:06 PM
sean23johnson's Avatar
sean23johnson
i am running nitto 285's and i love them. i dont have a lift and they are mounted on stock wheels. check my gallery for pics. i have 11,000 miles on them and they show almost no wear. i have always been a BFG man but i got these tires for a really good price and i would run them again.
Old Feb 26, 2007 | 07:34 PM
av226's Avatar
av226
Thanks for the information and advice.
Aaron
Old Feb 26, 2007 | 08:24 PM
TwelveAlpha's Avatar
TwelveAlpha
I used to have 285 BFGs and they fit fine on a stock truck. You might get a little chafe in the wheel well depending on how you drive (and where) but basically non issue. I got 40K out of them but I'm hard on them. A good chunk of that was toting a 12K trailer.
CrzHelm
Oct 6, 2011 06:46 AM
74baja
17
Aug 2, 2009 06:36 PM
74baja
Jun 25, 2009 10:34 PM
woody367
Sep 6, 2008 12:14 PM
Ford Truck Racer
Jan 4, 2007 09:38 PM
