Wow...
Old Feb 25, 2007 | 04:00 PM
shenders99's Avatar
shenders99
Wow...
So I have had my DP-Tuner for quite some time and really liked it though never got boost over 22ish, never set off the SES light and never had a serious amount of smoke. Mind you my highest setting is 80e and every day think that I should have gotten 140 too.
Anyway, I tighten all my boots yesterday and boy will I tell you, they were loose. Not more than 4 full revolutions each but that seems like a lot. Immediatley I noticed that my boost would build to 20+ at less than 40mph, I got up to 24 or 25 before the motor defueled. I even set off the SES a couple times. It's great, my grin is bigger.
So I think that this may be part of my 10-11 mpg I had recently. I think that I am going to replace my CPS and get a new one on evilbay. I'll fill up tomorrow and hopefully see a significant increase in mileage.
How often do you guys check the boots? how fast do they get loose?
Old Feb 25, 2007 | 04:11 PM
sean23johnson's Avatar
sean23johnson
did you notice cooler egts after you tightened up the boots?
i check mine every now and then.
Old Feb 25, 2007 | 06:16 PM
jvoigt's Avatar
jvoigt
Does anybody have a picture of these boots? I want to check mine but I am not sure exactly what you guys are talking about.
Old Feb 25, 2007 | 06:22 PM
Green_Dually's Avatar
Green_Dually
Look in this post.Post number 11 theres a pic.
https://www.ford-trucks.com/forums/5...-no-codes.html
Old Feb 25, 2007 | 06:24 PM
Uzumati's Avatar
Uzumati
2 blue boots on the orange pipe 2 black boots on the blue pipe and two Orange boots under the Y in the center of the motor
Old Feb 25, 2007 | 06:52 PM
jvoigt's Avatar
jvoigt
Wow those are some bright colors for an eng bay. thanks.......so how often can boost loss be contributed to these boots being loose? in other words how often do these boots wiggle loose?
Old Feb 26, 2007 | 08:41 AM
shenders99's Avatar
shenders99
My EGT's are at least 100 degrees lower than a couple days ago.
I think that might have a lot to do with the mileage problems that I was experiencing. I will update this later this week.
Old Feb 27, 2007 | 06:05 PM
shenders99's Avatar
shenders99
Mileage is back up. With 85 miles I filled up with 13.5 mpg, mind you I can't seem to keep my foot out of it now. I'll try harder again to get better.
This is a return from 9-10 mpg at the coldest of winter (which had a lot of excessive idle). Some of it may have been in part to a fuel filter.
Old Feb 27, 2007 | 07:59 PM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
OK, so I have to ask: What's normal boost? Boost of 20+ at only 40MPH?? I've NEVER seen that, but only had the truck since October, and am beginning to think something's really wrong. I've never gotten above 15PSI, whether I'm in STOCK, 80E, or the 120 setting. I've got new boots (all 6 and a 6.0 IC) to put on but the weather is just not cooperating. So, any suggestions on where to start?
Sorry to hijack but I've been wondering about this, and if Scott's boost is normal, I've got something wrong big-time...
Old Feb 27, 2007 | 08:07 PM
shenders99's Avatar
shenders99
I can hit 22 easy in 80e but the truck defuels. I need a overboost annhilator from IDP.
Normal operation in 80e keeping it under 2000 rpm's, I run between 2-10 lbs. If i get on it I will get up to 15 pretty quick, and i can get up to 20lbs by 45 mph at WOT.
Hope this helps...
Old Feb 27, 2007 | 08:13 PM
jvoigt's Avatar
jvoigt
Ok I tightened the two C-clamps with springs on the top right, And the two c-clamps on the top left.....But how tight do they need to be? and do any of the other c-clamps on those pipe's ever get a little loose?
Old Feb 27, 2007 | 08:21 PM
shenders99's Avatar
shenders99
Turn till it stops, don't torq it.
There are two more, the connections to the IC, the one on the drivers side is easy to get to, the other is under the Radiator Reservior and a little harder but not much. There are two more but I have not even looked at them.
Old Feb 27, 2007 | 08:25 PM
jvoigt's Avatar
jvoigt
Hey Shenders99,
So just tighten them until they stop or snug....even the ones with springs? I just dont want to split any of the boots by over tightening.....I guess its time to break out the built in elbow torque wrench.
Old Feb 27, 2007 | 08:27 PM
Uzumati's Avatar
Uzumati
Did you get the boots on the lower end of those pipes? They are down low on either side of the radiator and tend to seep the most oil.
Old Feb 27, 2007 | 08:29 PM
jvoigt's Avatar
jvoigt
Would them seeping oil explain why there is alot of soot/dust stuck on the pipes? I guess I will check them in the morning.
