Sponsored by: Real Truck
Rear gears??
Old Feb 24, 2007 | 11:48 PM
joenational's Avatar
joenational
Rear gears??
I have a 02 5.4 F-250xlt superduty with off road and tow packages. How can I tell that I am running with 4.10 gears in the rear? I am going to ASSume that I am since I have the full off road and tow packages but then again I dont know. Anybody have a way where I can tell.
Thanks,
Joe.
Old Feb 25, 2007 | 12:42 AM
joenational
I checked the VIN and it dosen't show it in there so any info would be great.
Old Feb 25, 2007 | 12:56 AM
metalman1320's Avatar
metalman1320
I had a tag on my front axle listing the ratio. If you don't have that, look in the SuperDuty FAQ tech folder. The codes are listed there. You'll just have to have the code that's on your door tag.
Or jack up the rear, mark the driveshaft and the tire. Then rotate the tire one full revolution and see how many times the driveshaft turns.
Old Feb 25, 2007 | 12:57 AM
hosemandc's Avatar
hosemandc
MIne has a tag on the dif that states the gear ratio.
