Can this be done?
Old Feb 24, 2007 | 09:24 PM
T1R1's Avatar
T1R1
Can this be done?
On my '88 f250 4x4 I have my engine out for a rebuild and decided to replace my C6 tranny at the same time. So the question is, can I unbolt it from the transfer case and pull it out without dropping the transfer case and drive lines etc.? Thanks!
Old Feb 24, 2007 | 09:51 PM
Conanski's Avatar
Conanski
I'm pretty sure the only thing hold the transfer case up is the transmission.
Old Feb 24, 2007 | 09:54 PM
Ohio Ford Farm's Avatar
Ohio Ford Farm
No.
The mount is between the trans and transfer but on the trans side. If you unbolt it there will be nothing to hold up the transfer case. Why not just take it out as one unit? Leave it bolted toghter. Its not that heavy unless is a OLD NP203 ( Full Time 4WD)
Old Feb 24, 2007 | 11:14 PM
T1R1's Avatar
T1R1
It just seemed simpler to block up the transfer case and unbolt the tranny than taking the drive lines and linkage out. Could be wrong thats why I was asking. thanks for the input.
Anyone know if there is a difference between a 4x2 C6 and a 4x4?
Old Feb 25, 2007 | 10:16 AM
Ohio Ford Farm
Yes tail shaft and tail houseing is differnt. I know that if you have the parts a 2WD can be changed to a 4Wd and soforth. I have not done it. A trany place should be able with no problems. Other then that there the smae on the inside.
Old Feb 25, 2007 | 10:28 AM
T1R1's Avatar
T1R1
Thanks Ohio!
