ECM code questions?
Old Feb 24, 2007 | 08:11 PM
mike manglos's Avatar
mike manglos
Question ECM code questions?
I just replaced my 4.9 litre 6-cylinder engine with another engine of the same
size in my 1996 f-150 4x4. I had 5 codes show on my code reader, and they are
102, 1401, 1131, 1132, 1151. what are the problems that are causing these 5 codes to show upon my code reader?
Old Mar 4, 2007 | 03:28 PM
ReAX's Avatar
ReAX
P0102 Mass or Volume Air Flow Circuit Low Input
P1401 Differential Pressure Feedback Electronic Sensor circuit High Voltage
P1131 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 1
P1132 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 1
P1151 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 2
Your having major problems with your emissions/af sensors. Start with checking for a vacuum leak, then by swapping the MAF with a known good.
