Bouncy Speedometer
Old Feb 23, 2007 | 10:23 PM
n2jqi's Avatar
n2jqi
Bouncy Speedometer
Well yall helped on my last post so here goes another.
1993 F150 300 auto trans 2wd.Problem?speedometer goes all over the place once speed hits 55 mph.Below 55 steady as a rock.Any ideas?
Thanks in advance
N2JQi
Old Feb 23, 2007 | 11:34 PM
ZonaNavyStar's Avatar
ZonaNavyStar
mine does this too, a 1995 F-150 351W E4OD. My 91 F-150 302 E4OD did it as well, screwed up the cruise control, but the newer truck it doesn't seem to effect the cruise. I would love to hear some help for this one as well, thanks!
Brian
Old Feb 24, 2007 | 12:19 AM
nighthawk285's Avatar
nighthawk285
check the Vehicle Speed Sensor, I believe it should be either in the tailshaft of your tranny, or the pumpkin of the rear axle. Your guys's are new enough that you have electronic speedo's in the dash, so it wouldn't be the cable.
Old Feb 24, 2007 | 10:36 PM
Old_Paint's Avatar
Old_Paint
It's in the pumpkin, and has been since '90, I think. I've heard a few in here mention finding chafed wiring about a foot from the sensor under one of the clamps or something. Check the wires from the VSS first to make sure they're not pinched or corroded, especially if you do any muddin in your 4x4's.
Old Feb 25, 2007 | 01:17 AM
nighthawk285
yep, you're right on that, did a little looking around, and the VSS is in the pumpkin, so like paint said, it could be a bad wiring thing (like a bad ground) or the sensor itself could be bad.
