I am installing a new wicked wheel and y'all's directions are great. I am having a problem getting the exhaust at the rear of the turbo to align so I can get the clamp back on. Is there a trick to it .....does this clamp need to be on before I bolt the turbo back down........ Any advice sure would be appreciated.
'99 250SD,7.3,CC,6637
Sorry you are talking about the up pipe to the back of the turbo.... I didn't tighten all the bolts down completely on the turbo when I did mine...I lined it all up..then put the clamp on... then tightened down the turbo... I hope this can help...
good luck,
Steven
There is an alignment dowel that is protruding from the exhaust up-pipe collector, that has to mate in an indent in the back (at the top, in the center volute) of the turbine housing. Chances are you do not have the dowel in the hole and it is not making the two flanges seat against each other.
Ohhhhhhh I will check it out, you're prolly right. Thanx a bunch
