Sponsored by: Auxito
Code Talk
Old Feb 22, 2007 | 11:09 PM
blieux1's Avatar
blieux1
Code Talk
Did a code scan on my wifes truck today. P0401 Exhaust gas recirculation flow insufficiant detected. P0402 Exhaust gas recirculation flow excessive detected. P0405 Exhaust gas recirculation sensor A circuit low. I need to know which O2 sensor A is. I assume all of these codes has to do with the O2 sensors.
Old Feb 22, 2007 | 11:11 PM
ford390gashog's Avatar
ford390gashog
Its not the O2 sensor that is a bad EGR valve hence the name "Exhaust gas recirculation sensor " also known as EGR.
Old Feb 23, 2007 | 12:07 AM
Racerguy's Avatar
Racerguy
Usually if you have a P0401 and 402 and 405 the problem is the DPFE sensor and it will need to be replaced.
If you do a search in the forum here you'll find lots of info on that.
Old Feb 23, 2007 | 08:03 AM
projectSHO89's Avatar
projectSHO89
EGR valves very seldom fail.
Codes at the same time that directly contradict each other are usually due to a faulty sensor, in this case the DPFE as Racerguy suggested.
Since those of us who have been around awhile have learned (like Ford) that their DPFE sensors were crap, just replace it wth the correct Ford (not aftermarket) replacement part.
Steve
Old Feb 24, 2007 | 08:55 AM
97texan's Avatar
97texan
I had P0402 code, I changed DPFE sensor,it fixed problem.Make sure you get sensor from Ford,aftermarket sensors don't last...
FI460
Aug 20, 2009 09:31 PM
scott4401
1997 - 2003 F150
Apr 13, 2009 11:24 AM
wildstang
Sep 3, 2008 09:36 PM
Ricohman
Modular V10 (6.8l)
Apr 19, 2007 09:16 AM
cinnpass
Jul 12, 2002 04:04 PM
