Charge light stays lit
Old Feb 22, 2007 | 09:00 PM
bruski127's Avatar
bruski127
My '66 F250 has this problem. The alternator tested good, replaced the regulator, and field relay ( w/ a horn relay that looks the same phisically), and the idiot light stays lit. It actually brightens when the engine is revved.
A multimeter at the battery tells me that I have 13.83 - 14.03 volts coming into the battery. I'm stumped. Any ideas?
Bruce
Old Feb 22, 2007 | 09:17 PM
airharley's Avatar
airharley
Have you disconnected the relay from the altenator, ran a jumper, and checked for the light? Run the jumper from the starter soleniod to figure out if it is the wire coming from the altenator. Check for a short in the wiring to and from the relay or a grounded wire in the dash.
Old Feb 23, 2007 | 11:22 AM
jethro1's Avatar
jethro1
I have the exact same problem in my '64. I have concluded that the universal ignition switch installed by the previous owner is the culprit. I'll be installing a Ford correct ignition switch as soon as spring arrives. Check your ignition switch connections.
Old Feb 23, 2007 | 01:02 PM
Customcab's Avatar
Customcab
Bruce;
I'm no electrical troubleshooting guy;(Airharley advice will always over ride mine) but I have had a similiar problem in the past; it was the voltage regulator on the front radiator brace; that was out on my 66 to cause the same problem.
As for Jethro1; those 64 & below 6 volts a hold different playing field for me with those resistor's.
Mitch
