Does anyone have any suggestion for fixing plastic parts problem. I have work truck that cannot keep a emergency brake working because the plastic adjuster bracket and release handle are plastic and the replacements are all plastic and keep breaking.
Sorry to hear about your problem but you will need to post your question in the tech forums since this one is used for introductions. Click on the Forums tab at the upper left and look over the choices. Your question may be a bit tough to get an answer for but you can try in the Super Duty forum or you might want to try the Aftermarket forum.
