6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
turbo placement
Old Feb 22, 2007 | 07:07 PM
F6Guy's Avatar
F6Guy
turbo placement
I am a gasoline person myself, but must say the diesels are nice I just don't pull enough to warrent the extra expense of a diesel. I do have a question about the turbos. I could not beleive ford found enough room to stuff another turbo under the hood, so my question is why not put them under the bed of the truck? I have seen aftermarket kits for cars that mount the turbos behind the rear axle, about 1pound of boost is lost but the intercooler efficiancy is much higher not to mention the reduction in underhood temps which would be of great help to all the electronics on these new diesels. any comments.
Old Feb 22, 2007 | 07:13 PM
Layson's Avatar
Layson
It would be cool and alot more room.... but man that could possibly be a tubing nightmare plus the turbo's need oil to get to them... would be cool though..
2001 F350 CC LB 4x4 SRW, Build date 9/00, 6" Lift, 37" Toyo MT, 22" MKW M19's, Superchips, Banks Transcommand, GTP38R, 4" exhaust SAVV Back up System, 05' Conversion w/ Mirrors , AFE2, Truspeed, Isspro Guages, ORU Diff Covers, Hella 500 Lights, 37G Transfer Tank, AIH Delete, JJ's, Excursion handles, ITP Boost fooler, AMP powerstep on the way!
Truck Pics,
More Truck Pics
New Badges from Billet Badges
Check out Badge Pics
Tribute Pages
Myspace Tribute Page
Iraq War Heroes Tribute Page
Don't Let The Memory Of Them Drift Away
Old Feb 22, 2007 | 07:47 PM
vloney's Avatar
vloney
The turbos are about 4" in diameter, back to back, mounted transversely (fender to fender). As far as heat, this motor in some areas, thrives on heat. Then again, it has more coolers involved to dissipate heat.
Old Feb 22, 2007 | 09:12 PM
rollerstud98's Avatar
rollerstud98
Beautiful badges layson
Old Feb 23, 2007 | 06:20 PM
F6Guy's Avatar
F6Guy
I don't think the plumbing would be that bad. the exhaust is there already, all you would have then is the intake from the turbos to the intercooler. Some stainless braided oil lines and presto. If I remember correctly the intercooler efficiancy went up to like 98%.
Old Feb 25, 2007 | 05:24 PM
MrMike06's Avatar
MrMike06
Yeah but with the turbos under the truck, you now have to take into account road debris, salt, ect. Its a good idea for tight areas, but its more acceptable to the elements.
Old Feb 25, 2007 | 05:55 PM
Strut61's Avatar
Strut61
The Turbos are not located under the truck, but rather on top of the motor just as before.
Old Feb 26, 2007 | 11:11 AM
sprintenduro's Avatar
sprintenduro
My guess is assembly would be harder to do. With the engine basically coming in as a complete module, it is plug and play as far as assembly goes.
Old Feb 26, 2007 | 11:44 AM
BowTieHatr's Avatar
BowTieHatr
turbos under a vehicle is not very practical due to everything. these vehicles have to meet 50 state requirements when coming from a dealer. that means if you have a truck in sc it will last in california, or anywhere else. alot of r&d is done on vehicles nowadays to try to eliminate simple issues. besides, i think the turbos fit rather nicely up top.
Old Feb 26, 2007 | 01:07 PM
origcharger's Avatar
origcharger
If the turbos go under the bed where does the particulate trap go?
Old Feb 26, 2007 | 01:45 PM
fpd7's Avatar
fpd7
The new turbo placement increases the combustion efficiency sufficiently that there are no longer any particles, so a particulate filter will no longer be necessary. Also, MPG goes up about 34%. It's a secret being held by the FORD Administration, it's coming out in 2010 Model Year.
Old Feb 26, 2007 | 01:49 PM
BowTieHatr's Avatar
BowTieHatr
if only that was so!!
Old Mar 20, 2013 | 09:38 AM
countryboy73703's Avatar
countryboy73703
not to be rude, but these are Super Duty trucks for a reason.... not rice burners.. it's not practicle, plus as stated earlier, salt sand and rock hitting it doing 70 MPH down the road.. and IMO, that turbo gets dam hot... so when rain water or a flooded intersection hits the hot turbo, it's going to thermo shock the casing... which means it could crack it, and then your out a turbo... it's just not practical for the vehicle or the application... under the hood is a perfect place... other then its crammed in there with everything else.. again.. wasn't being smart, just realistic..
Old Mar 20, 2013 | 09:42 AM
senix's Avatar
senix
Holy Batman..talk about an old thread...this is back from 2007
Old Mar 20, 2013 | 09:54 AM
countryboy73703
I was researching and this came up.. Lol. Had to make a statement here.. Sorry. :-)
