changing spark plugs
Old Feb 22, 2007 | 02:38 PM
fordblue_ca's Avatar
fordblue_ca
I have recently replaced my spark plugs it was a paint in the a$$ but I got them all but the one on the rear of the engine on the passenger side, anyone know any tricks to get to it I can even touch it!.
Oh yeah 2002 ford sport trac
thanks
joe
Old Feb 22, 2007 | 03:14 PM
CobraXP's Avatar
CobraXP
Did you go through the top of the engine or did you go through the fenderwell?
If you look in the fenderwell, there is a flap there that can be removed. Remove it and you are staring right at the plugs...
Old Feb 22, 2007 | 05:41 PM
rds4ou's Avatar
rds4ou
Going in from the femderwell was the easiest way for me. A friend and I used a spark plug socket with a hex at the end and used an open end wrench to turn it.
Old Feb 22, 2007 | 06:36 PM
marragtop's Avatar
marragtop
Definitely thru the fenderwell, and make sure you use anti-seize.
Old Feb 24, 2007 | 07:30 PM
fordblue_ca
got the last plug out not easy but took everyones advise and went through the fenderwell glad it does not have to be done for a long time now! lol
Thanks for the help,
Joe
