problem with ford exploer
Old Feb 22, 2007 | 09:46 AM
taz1y's Avatar
taz1y
hey i have a 1991 ford exploer i put a new started on it and new silanoide on and when i hook up the battery cable it's want's to roll over and the keys is not in the ingoiny can some one help
Old Feb 22, 2007 | 10:25 AM
marragtop's Avatar
marragtop
Are you sure you hooked the cables up properly on the solenoid and starter?
Old Feb 22, 2007 | 10:47 AM
mikeinri's Avatar
mikeinri
Definitely double check the wiring on the solenoid and starter (use a wiring diagram from a manual).
If that checks out, there's a very slight possibility that the new solenoid is bad, but that seems highly unlikely (normally, when they fail, they don't actuate). But since it's a new part, there's always the remote possibility of a manufacturing error.
Hope this helps.
Mike
Old Feb 22, 2007 | 11:23 AM
87 XLT's Avatar
87 XLT
If you remove the wire with the rubber boot from the starter relay & then connect the battery does it still crank with the key off?
Old Feb 22, 2007 | 03:16 PM
taz1y's Avatar
taz1y
Smile
hey thanks guys for the info got my exploer going it was b brokeing wire and the wires where on wrong thanks again guys for the help
Old Feb 23, 2007 | 08:07 PM
bcjim's Avatar
bcjim
Glad it worked out. What language was that?
robert depasquale
Jun 6, 2014 06:48 AM
stcspiderman
Jan 20, 2014 11:44 PM
jackchan
13
Jun 3, 2006 09:41 AM
jcv44wf
Electrical Systems/Wiring
Mar 28, 2004 01:07 PM
jcv44wf
Mar 28, 2004 12:15 AM
