352 Exhaust....???
thanks
John
https://www.ford-trucks.com/user_gal...143324.520.390
It was heavier than a '65 F-100. I know because that was the next vehicle I had after I rolled the big Merc on I-5. (The accident happened within 12 hours of the picture shown and relates to the tongue on the trailer being much too short. High-speed fish-tailing. I still have the trailer and only use it behind my '68 F-350 DRW.) This is the short version; if anyone wants more details, I would love to help anyone avoid being upside-down at 60 mph.
The valve burning comes from using a high-compression (or even medium-compression) engine to produce continuous power. The 390 in my old Merc (my Dad picked it up new at the factory), had its 390 re-built with 410FE pistons (on purpose). They are about 1/10" down the bore at TDC and give around 8:1 compression ratio. This keeps temperatures down so that exhaust valves can survive.
My F-350 was put together by a savvy guy that taught Ag implement design and he tried a 428FE first and had a terrible time with burning valves. (I have a similar story about a 406FE.) High compression engines make more power per cubic inch, but they cannot do it for a long haul. After the 428FE came a factory rebuilt 319FT engine which has a compression ratio of 8:1 or less AND sodium-cooled exhaust valves. He used that engine for 400,000 miles of hauling machine tools as a side business. By the way, the right-hand exhaust manifold was the 390FE manifold that everyone (including me) hates. The exhaust system was dual.
The K&N air cleaner is OK, but will not really change anything at hauling rpm's. Compression ratio is the key. (I was just ribbing the "go fast" crowd about 75 mph -- I am usually between 50 and 60.) If a high-compression engine is kept wound up, the average temps would be lower, and there would be more air moving through for cooling. This is not the best solution because gas mileage would not be very good.
Regarding Tri-Y headers, let me dig in my archive. As I remember there were two companies that offered similar ones to those shown in my album. I will do another post to answer that part.
My original advice still stands. I would stick to adding dual exhaust to stock cast-iron manifolds. Save the $$$ for building a hauling engine that will survive. More later . . .
www.stans-headers.com
www.fordpowertrain.com
These appear to be very high quality (the price certainly is high). At least one was available with an extra-thick (3/8") head-flange which is what will help keep leaks down. They are also available in chrome or ceramic coating - at extra cost.
Another thought: when you do take the heads off of your 352, replace them with heads from a 390 or larger FE engine to get that compression ratio down. (ALL new valves, valve guides, & seats; & surfaced.) You could do this first and then move those heads to another engine if the 352 rings or bearings give you trouble. Although your 352 will run on regular gas, it would probably live longer with intermediate grade. Although a low-compression engine might seem to be sluggish, it will run on just about any gas you can buy.
The seats are important. The seats in your original head were "integral" -- that is they were machined right in the cast-iron head, with no separate insert. This worked great in the days of leaded gas. Valves ran cooler because there was one less interface between them and the water jacket. Small lead oxide particles acted like miniature ball bearings and wear was not a big problem. Take the lead away and the valve starts wearing its way to that water jacket. After my first towing trip, the (original) engine had a slight miss. When I pulled the heads, THREE of the valves were "on their way to China". I put another pair of heads on that had hardened seats, wore out that engine towing for five years, had a "touch-up" valve job done, and did some more towing with those heads on another engine.
I must have some magic exhaust valves in the warmed over 414 as it has seen hours at 90 mph with many full throttle runs in the 120+ mph zone, no
burnt valves.
Yes with headers and new to me by acheda after 40 years running them drag strip only open headers on the street with those extremely large 2 1/2" collectors on what must be extreme also 2 1/2" exhaust system.
The whole 390-series FE engines are car & light truck engines. For real trucks, Ford modified the design to the FT series. Many of these included sodium-cooled exhaust valves and all had low compression ratios. Hauling/towing with our pickups puts them under load for long periods of time, climbing grades, etc. What works well for a quarter mile does not for haulers. Compression ratio is part of the solution if one wants to haul with an FE. Sodium-cooled exhaust valves are expensive and I will have to by a set if I rebuild my 391.
many members run headers and higher rpms plus use 'em as work trucks.
A F350 is one working truck be it "light truck" vs your box trucks
i'll give you that.
Sodium valves, they were the death of 427 cammers at one time.
Headers and "burnt valves" we'll just your opinion I must add.
Not busting your chops just adding my opinions like you have
been be that they are different than mine.
I pull boats at times up and down California's valley with 9.29 cr
without overheating or valve problems with stainless valves without
being a low compression dog, going on 248K. Not a special built drag truck.
Glad we are OK. I may not invest in rebuilding my 391FT due to the cost vs. the actual amount of hauling ahead of me. (I made many trips hauling all my shop stuff from CA to MD, but that is behind me.)
I did the last of my cross-country hauling with a '65 F-100 390 with a Crane cam, but I ran premium gas and did not push it as hard up the grades. The main reason I am stressing compression ratio to BlueOvalBud is that he asked if he could haul 12,000 GCVW with his F-350 with a 360. If you have to pull grades, you need to lower compression ratio to get it to live. I made refererences to the FT engines to show that Ford engineers knew this.
The 406FE I refferred to was an long experiment in trying every kind of exotic valve available. Its regular route took it over a long grade, pulling a stock trailer. They never found a valve that would hold. (If the driver had been willing to gear down more and keep his foot out of it, it probably would have lived, but he was in a hurry. That kind of hauling is diesel territory, in my opinion.)
Let me finish by agreeing with you that a low compression ratio engine is a dog. This is why I built the '65 F-100 390 to be a sharp-running engine. (I just did not plan on the price of gas going up so fast.)
P.S.: I hope no one thinks I said headers burn valves. I am saying that adding dual exhaust to stock 360 will be good first step for someone who has to budget. THEN, I would go with big chamber heads before investing in headers. If there is money left over, then buy the headers. A 4-barrel carb is nice, but if you keep your foot in it on a long grade you will stress your exhaust valves. (This is why diesels often have pyrometers in their exhaust so that they can avoid pushing it too hard.)
Many people only look at a build at
reaching maximum numbers in hp/tq on
the dyno. This is ok for instant numbers
as well running maximum advance, even drag
motors have to pull retard at top end as the
combuston chambers heat up preventing detonation.
Pulling a grade under load for 10 minutes is totally
different than instant high hp/tq dyno numbers i'll agree.
On your old truck with a 390 you should of built a 410 or
with todays 4.125 or 4.250 cranks available now were talking
torque to pull.
Big radiator like a 5 row stagger i've never had a cooling problem.
I had a 4-row radiator and found it to do the job. There is no substitute for cubic inches, but you are right -- the radiator has to be sized up with the engine.
These are the rods I have in the 414.
That motor sounds like it had a meltdown early in life causing butted rings.
Check the numbers on the block, might have thick walls.
I wonder what happened to BlueOvalBud? Looks like we are having all the fun?
