Sponsored by: Kumho
76 F250 steering issues
Old Feb 21, 2007 | 05:22 PM
ShamelessMT's Avatar
ShamelessMT
First off, I have a non-factory power steering unit that was mounted in my truck by the previous owner (box welded to frame rail). Recently I've been noticing that my steering wheel is rotated differently and shifts position occasionally. I notice this when driving straight down the road. To clarify, sometimes I'll get in the truck and the steering wheel will be rotated correctly (straight up and down orientation) and sometimes it will be off (rotated cntr-clkwise) a few degrees. There is no shimmying in the wheel while driving and it never changes its alignment while going down the road, just in slow speed, full lock manuevers. Like the shaft and gears inside the box are slipping past each other.
Anyone know what this is and how I would begin to remedy it?
Sorry about the long post, but any help would be greatly appreciated.
Old Feb 23, 2007 | 06:05 AM
SRD4X4's Avatar
SRD4X4
Something is moving.Have someone turn the wheel lock-2-lock while you look at everything underneath.Could be as simple as a axle pivot bushing.A common problem (more common on the 80-86,than 67-79)is the rivots"loosening" at the frame and crossmember.
Old Feb 23, 2007 | 06:14 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Considering that someone welded the steering gear box to the frame (!!), I'd look at the steering column to dash mounting bolts. If loose, the wheel will move in all directions. The steering coupling is another source of problems, if it has one (it did at one time). Under the hood, the coupling connects the steering shaft to the box. It has a piece of rubber, which gets oil soaked.
If the axle pivot bushings are bad, figure radius arm bushings too. Forget the originals, go with polyurethane ones. they'll last a lifetime.
