91 ford e150 van abs help
Old Feb 21, 2007 | 03:06 PM
robertbourque's Avatar
robertbourque
im converting my efi to carb so im removing everything the computer the wire harness .will the lock brakes still work is there a seprate computer that controlls the abs .any info would be great .thanks
Old Feb 23, 2007 | 09:03 PM
Redcat Diesel's Avatar
Redcat Diesel
There should be a seperate module for the abs under the dash.The last one I worked on for an abs problem was a 94 [I think] E250.It was just to the right of the steering column.The abs does not communicate thru the data link so I would think it's not tied to the engine computer.Hope this helps.
