Be carefull with high pressure hose coming off the compressor. With that reading it will be very hot and under alot of pressure. You have a compressor problem.
perhaps there is air in your system or you have a blockage. Is there a bunch of crap or leaves or anything between your radiator and condenser? your high side pressure should be like 145 and low should be oh say 30 while the car is on. If you can measure them both you could tell us and we could help with zone diagnostics. you dont know what that is but we do and we can help
Take the truck to someone who knows what they're doing.
It is perfectly normal to have a high pressure reading on the low side port when the compressor isn't engaged. Since you already have this, you proabably don't need refrigerant, you need a proper diagnosis and repair, usually an electrical fault, sometimes the clutch.
