Sponsored by: Real Truck
changing filter and fluid
Old Feb 21, 2007 | 12:15 PM
getnbz's Avatar
getnbz
i have a 99 and i want to change filter and fluid and install a sonnex valve how much fluid i need to replace.
Old Feb 21, 2007 | 12:59 PM
Casey's Avatar
Casey
This should answer all of your questions:
https://www.ford-trucks.com/article/...nsmission.html
Old Feb 21, 2007 | 04:26 PM
hydro_37's Avatar
hydro_37
Check out Casey's site. It is very good info and worth printing out for reference while your doing it.
Old Feb 21, 2007 | 05:46 PM
Pocono Super Duty's Avatar
Pocono Super Duty
Wait a minute. My owners manual & the Ford parts guy said to use "Mercon V" for the 4R100 transmission (2004 F250). Does someone know different?
Found this also:
MERCON® V
Beginning with the 1997 model year, Ford introduced a higher performance level ATF with the MERCON V specification. Many Ford automatic transmissions from 1999 on will require a MERCON V fluid. The most notable exceptions are the E40D, 4R100, and CD4E transmissions, which still specify regular MERCON ATF.
Old Feb 22, 2007 | 08:28 AM
Casey's Avatar
Casey
Ford changed recommendations recently. They are dropping MERCON this year, and they claim that they have changed MERCON V to be compatible with everything that used to require MERCON.
Old Feb 25, 2007 | 08:28 AM
FORDDIEHARD's Avatar
FORDDIEHARD
I also changed my tranny fluid on my 2000 F-250 4x4 crew Lariat with 84000 miles. I used Casey's site and followed the instructions to a T. Very well written and easy to follow, Kudos to the original author. That is why FTE is such an awesome site, people helping others and shareing there knowledge.
Thanks
Tim
I also went thru the manual and for a 2000 they recommended regular Mercon ATF.
Just my 2 cents
