1978 - 1996 Big Bronco
Keyless Entry???
Old Oct 16, 2002 | 06:31 PM
speedspecialists's Avatar
speedspecialists
Post Keyless Entry???
Hello I bought a 95 Bronco XLT it did not come with remotes. How can I tell if it came equiped with keyless entry. If so is there a way to program remotes if I get them from the dealer. Thanks.
I am new to this forum. Thanks for the help.
Joe
Old Oct 16, 2002 | 08:23 PM
1956MarkII's Avatar
1956MarkII
Keyless Entry???
I just dug out some old Ford info, so I hope this works. You'll need to borrow a friend's remote for this to work; if it does, then his remote is now programmed to your vehicle. I guess you'll have to buy him a new remote! If it doesn't work, then you know your vehicle never had KRE. Here goes: Turn ignition to RUN or ACC. Momentarily jump pins in programming connector located at the base of the steering column. All doors will lock then unlock to confirm programming code. Press any button on 1st transmitter. The doors will lock then unlock to confirm programming. Press any button on 2nd transmitter (up to 4 transmitters total possible). Turn ignition to OFF. The door locks will lock then unlock to confirm programming.
Hope it works! If you want to add more transmitters later, you'll have to re-program all the remotes that you already programmed. And this information comes to you from a CAR SALESMAN!!! See, we're not all bad guys...
Old Oct 16, 2002 | 10:09 PM
CityBronco's Avatar
CityBronco
Keyless Entry???
Old Oct 17, 2002 | 10:38 AM
adelyser's Avatar
adelyser
Keyless Entry???
Ford also offered a security system that uses different remotes and programming techniques. My EB came with a dealer installed Ford security system. It has a red LED on the dash, and a pushbutton on the sidepanel by the E-brake release. If you have this setup, you will need a remote from Code-Alarm (sp?).
