6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Receiver Hitch Compatibility
Old Feb 21, 2007 | 10:00 AM
havinsunfunnow's Avatar
havinsunfunnow
Question Receiver Hitch Compatibility
I currently have a 99 F250 SD PSD LB SRW 4X4 Offroad and have installed a Reese Titan Class 5 hitch with the 2 1/2 " receiver. I have ordered an 08 F250 SD FX4 PSD CC LB SRW which comes with the 2" receiver. My current Reese hitch is compatible up through the 07 F250/350 SD.
Does anyone know if I can replace the OEM receiver with my Reese Titan. I run a Lance camper and need the 2 1/2" receiver for the hitch extension tube under the camper overhang.
Thanks for any info ! ! !
Ron
Old Mar 20, 2007 | 07:31 AM
geostorm450's Avatar
geostorm450
Don't know if it's compatible ,but the DRW 08's come with a class 5 stock. I've ordered an 08 KR SRW and requested that they put on a class 5.
Old Mar 20, 2007 | 07:41 AM
Strut61's Avatar
Strut61
I believe they come with a 2 1/2".....My 08 F450 has a 2 1/2" with an adapter "Tube steel" for reducing to 2".
Old Mar 20, 2007 | 08:51 AM
havinsunfunnow
Smile
Geostorm and Strut - Thanks for the info. The Reese Titan did in fact fit the 08 F250. Only issue is the 18" spare tire sits right against the back of the receiver. The part of the receiver that goes from side to side is straight whereas the OEM has a curve to it. This curve gives about a 2 inch gap between it and the spare tire.
The bolt holes for the Reese match perfectly as they did with my 99 so no drilling was required.
Ron
snowdog79
All Things Towing
Aug 8, 2013 10:38 AM
jh225
All Things Towing
Jun 29, 2012 07:12 AM
System
Aug 22, 2010 08:18 AM
Batgeek
All Things Towing
Mar 7, 2006 08:55 AM
DanMartin
All Things Towing
Mar 7, 2004 11:24 PM
