Aerostar Ford Aerostar
Does a '93 have an optional tach?
Old Apr 9, 2007 | 12:33 AM
asavage's Avatar
asavage
FTE Community Team
Well, damn. Then I guess I'll have to just go all the way to either the ICM on the right fenderwell, or the coil at the rear of the engine.
Or study the diagrams more. The digital dash got a tach lead that apparently is not present in the analog dash version of the harness. That lead is a tap on the line between the coil negative and the ICM. It connects to the dash via C212, which is supposed to be in the engine compartment below the PCM connector -- or under the PCM, inside -- the text seems contradictory in the EVTM and the illustration is unclear on this. At any rate, I haven't found it, if it exists.
Anyway, I am tired and am going to bed now.
Old Apr 9, 2007 | 01:37 AM
96_4wdr's Avatar
96_4wdr
http://www.sunpro.com/tech_tips_deta...id=16325&id=21
select Ranger or Explorer
Old Apr 9, 2007 | 08:14 AM
asavage's Avatar
asavage
FTE Community Team
Originally Posted by 96_4wdr
Yup, all old 3.0l on the chart send you to the ICM on the right fender.
Old Apr 9, 2007 | 08:26 AM
Bear River's Avatar
Bear River
Former ******
I would tap the coil output. Thats what we did on my mom's 3.0L. Its an easy location to get to and it is closer to the dash. You just take the cupholder out, maybe loosen the ABS module and then take the cover off. You will probaby want to drill through the firewall. They include rubber grommets with the tachometer kits.
Old Apr 9, 2007 | 10:39 AM
asavage's Avatar
asavage
FTE Community Team
The SPOUT (spark output) connector has 46Hz at cold start (46 / 3 * 60 = 920 RPM), and 35 Hz when warmed up a bit ( 35 / 3 * 60 = 700 RPM). Might work.
49fordv8f4
Sep 22, 2022 05:35 PM
89LX306
All Other Items for Sale
Jun 10, 2014 02:22 PM
barnfind 51
Sep 26, 2011 10:16 PM
93bigbronco
1997 - 2003 F150
Jun 1, 2002 09:54 AM
Crystal
Aerostar
Feb 12, 2002 10:55 AM
