EGR start problems!?
Old Feb 20, 2007 | 07:35 PM
vatreefarmer's Avatar
vatreefarmer
Dealer tech says cold start issue may be due to EGR, wants me to reschedule when part arrives. Symptoms are truck dying 3-4 seconds after a cold start unless given additional throttle. 2nd start attempt immediately dies, 3rd crank usually will run but I know to give additional throttle by then. This only happens at below 35 degrees, otherwise truck runs like a top once warmed.
Don't have new flash yet
Dealer says injectors are OK
Could a bad EGR cause this problem?
Old Feb 20, 2007 | 08:06 PM
vloney's Avatar
vloney
The new flash will probably fix your troubles.
Old Feb 20, 2007 | 08:18 PM
BowTieHatr's Avatar
BowTieHatr
i say bad dealer. tighten loose bolt behind IDS and rd test lol. try another dealer, you will be glad you did.
Old Feb 21, 2007 | 08:33 AM
Duksrule's Avatar
Duksrule
Tighten loose bolts? I am having a cold start issue too. Sometimes truck will start right up, other times it acts like a flooded gas motor. Normally happens below freezing but doesn't happen 100% of the time. I have been plugging it in now when it is cold but would like to fix it.
Old Feb 21, 2007 | 03:45 PM
BowTieHatr's Avatar
BowTieHatr
that was a joke by the way. injectors are probably your problem if plugging in fixes the issue for you as well duksrule
Old Feb 21, 2007 | 05:31 PM
npccpartsman's Avatar
npccpartsman
LOL--that's funny rite thar I don kar wut any 1 sez
