Aerostar Ford Aerostar
where to find
Old Feb 20, 2007 | 07:12 PM
VanGo's Avatar
VanGo
where to find
I can't find Motorcraft double platinum spark plugs. The best I can do is Autolite double platinum p/n APP765. Are these any good?
Old Feb 20, 2007 | 07:44 PM
96_4wdr's Avatar
96_4wdr
the best, what I'm running now
Autolite makes Motorcraft
Motorcraft has no manuf. div.
Old Feb 20, 2007 | 08:27 PM
VanGo's Avatar
VanGo
Thanks 96. Now I just need to order wires.
Old Feb 21, 2007 | 05:41 PM
Aeroman59's Avatar
Aeroman59
I have Bosch platinums in mine, so far so good ! (16 months, 23,000 kms ).
I think if I had been on this Forum when I changed them, I would have put Motorcrafts in though. The originals went 238,000 kms! I did have a bit of a misfire in adverse conditions after 220,000 kms, but not enough to damage the catalyst. What put me off was getting to the plug through the inspection door, but in the end I found the secret position which enabled me to get in at the correct angle & thread the thing in without crossthreads ( lying on my back across the seats & basically FEELING it into the plug hole!). It took me almost a whole day to do the entire job; but rather that than pay $600 for the Ford service.
Old Feb 21, 2007 | 07:01 PM
xlt4wd90's Avatar
xlt4wd90
Autolite double platinum plugs canbe gotten from your local Walmart stores
Old Feb 21, 2007 | 09:20 PM
VanGo's Avatar
VanGo
I have the Bosch plats in mine too. My Aero pings bad in the summer on regular and my idle isn't as smooth as it could be all year. I'm hoping the new Autolites and wires help. I've tried everything else.
Old Feb 21, 2007 | 09:44 PM
Bear River's Avatar
Bear River
Former ******
Thats why one of the reasons the Bosch plugs don't work. They get way to hot. They don't last long either, they melt down. When we switched to the Autolites and used the proper wires, all problems with the ignition system vanished.
Old Feb 21, 2007 | 10:10 PM
96_4wdr's Avatar
96_4wdr
vango,
good luck w the A.L.'s
the double plat APP765 Autolites for the 4L OHV may be discontinued by A.L., I'm getting conflicting info on their APP line standard core w plat welded on tip and bent steel ground side electrode w plat welded on tip.
may be replaced by their Iridium fine wire series so they will only have one line of long life protected firing tip and ground elctrode plugs
buy 'em while you can get'em, 1/3 the price of the Iridium fine wire tips
