How "rare" is your truck...?
Old Sep 27, 2020 | 04:23 PM
  #136
Diesel_Brad's Avatar
Diesel_Brad
Originally Posted by Surgemaster1277
My 91 F250 is called a F250 Super Custom XL 2wd edition....It has a F350 frontend with heavy duty F350 rear leafsprings and can handle alot more than 3/4 ton has thicker plating on the metal and also came with an engine block heater in a 5.8 gas engine.....
It has no power windows no power locks no airconditioning,came with an AM radio,no tilt wheel but does have full instrumentation and delay for the wipers..Its a no-nonsense hardcore 2wd worktruck that could get me anywhere even through the snow mostly throughout its lifetime without the aid of tirechains or the need for putting 4wd...LOL
The engine block heater is part of the key as to why the truck lasted 29 years on the same engine and accumulated 565,000 miles before needing a fresh mill also the fact that it was built with a S42 5 speed ZF and doesnt need to be revved past 2500 to shift it when driving it normally...
You do realize everything you listed is a load of crap, right? F250 and F350 have the same front ends, and the same available leaf springs. Then there is the "thicker metal plating". Another load of crap
Old Oct 12, 2020 | 06:35 PM
  #137
John SCB's Avatar
John SCB
Originally Posted by eagle275
I have same engine and gears and tranny 96F350 SRW Long bed 4x4 and has Gear Vendor O/D 116,000 miles and maxon liftgate that is nice to have it saves my back Lol!
Here's another one with just 16k miles. One owner. Wow.
https://bringatrailer.com/listing/19...-f-350-4x4-12/
Watching it for sure.
Old Oct 12, 2020 | 08:36 PM
  #138
Muni's Avatar
Muni
Maybe by same front end me means solid front axle. Isn't that the only real difference between the f250 and f350? The thicker metal plating and leaf spring thing...yeah that's obvious BS
Old Oct 12, 2020 | 09:36 PM
  #139
Muni's Avatar
Muni
Mine is an old forest ranger truck. I don't know if that makes her rare, but I sure haven't seen one this color before
Old Oct 12, 2020 | 09:40 PM
  #140
DesertF350's Avatar
DesertF350
If he has the HD version his frame is thicker, like the F350's.
Old Oct 12, 2020 | 11:20 PM
  #141
rclc's Avatar
rclc
Trailering
1992 Flareside 5.8
Still trying to get a picture of me 92. Flareside 4x4 5.8 XLT Automatic 163K.
Old Oct 13, 2020 | 07:56 AM
  #142
Diesel_Brad
By same front end I mean the SAME FRONT END. Identical parts used on both the 2wd f250 and f350
Old Oct 13, 2020 | 12:05 PM
  #143
DesertF350's Avatar
DesertF350
They are not the same, why would Ford even have an F350 model if you could order an F250 the same? Read the Spec. chart it clearly shows the F350 has higher rated spring options than the F250.
Even the front end is rated higher on the F350.
Old Oct 13, 2020 | 06:27 PM
  #144
DaBrkddy's Avatar
DaBrkddy
Not sure how rare mine is, but I've got a:
1992 F-250 XLT SCLB
460, 4wd, ZF5, SRW Sterling 10.25
145k Miles
I'm not sure whether I've got LSD axles or not (seems doubtful) and I've been told by the previous owner that it's an F-250 HD but I'm not sure if that's true either.
Old Oct 14, 2020 | 05:12 PM
  #145
Diesel_Brad
I really dont care what that chart says. they use IDENTICAL parts. Look at the door jam of a f250 and F350. they have the SAME spring codes
The same goes for the rear. EVERYTHING is identical other than the rear blocks but the f350 is rated higher
Old Oct 14, 2020 | 06:47 PM
  #146
cougrrcj's Avatar
cougrrcj
I found out how 'rare' my truck was when it came to buy parts for it. Just about NOBODY's parts catalog listed that Ford EVER made a:
'97 F-250HD ext cab SHORT bed XLT with a 7.5L (460)/E4OD/4.10 posi. Long bed, yes, short bed no. From what I was able to learn, they were made in very small quantities for less than a year covering late '96-early '97 production..
I'd have to SPELL OUT that the '97 F250HD was old body style, and the '97 'light duty' was the new body style. SOmetimes I'd just short circuit the process and say that I had a '96
BUT---
THEN there were the mid-year changes - like finding the correct power steering line! Because they had a bulge in the tube that fit waaaaay down inside the steering box in order to seal properly. Or even the front radius arm frame bracket... Or the... Maddening!!!
Old Oct 15, 2020 | 04:45 AM
  #147
Diesel_Brad
BUT---
BTW ford never made an extended cab . They make supercabs. They also made them supercab short bed f250s 95, 96 and 97. There was a new body style 97 as well. But if you just refer to your truck being a 96 it will eliminate any confusion
Old Oct 26, 2020 | 10:02 PM
  #148
animator's Avatar
animator
Originally Posted by John SCB
Here we are 10 years later. I refreshed the truck 2 years ago with new paint, trim, rubber, glass and new leather steering wheel. Still going strong with 193k miles. Some guy offered me $15k unsolicited. Maybe on eBay one day.
old post on an even older thread, but to this day, this is the only other truck I’ve seen, either online or in person, with the same metallic smoke paint as mine, and mine also has black from the lowest body line down, and I have yet to see another one with that combo.
mine’s a 93 single cab short bed xlt 4x4 with a 300 and m5od.
Old Feb 10, 2025 | 07:52 AM
  #149
jwmustangman's Avatar
jwmustangman
I know this is an old post, but I have the SAME TRUCK! mine is a 1992 and was sold to USFS outside Atlanta. I'll get a pic and add it soon.
Old Sep 9, 2025 | 09:05 PM
  #150
06f35097f350's Avatar
06f35097f350
I've got a 97 f350 cc 2wd dually with an OBD2 mass air 460. I know they were only sold in California and maybe Mass, and only in 96 and 97. I know they're pretty rare in terms of the 460 but I've often wondered how many were made and how many are still in the road, especially in my configuration.
