Quick Pyro ????
Old Feb 20, 2007 | 12:29 PM
Ford_dad's Avatar
Ford_dad
Question Quick Pyro ????
Hello fella's (and ladies). I have a quick questions, Which is better drill and tap or clamp on style pyro??? I am not worried about drilling and taping the manifold, or drilling the up pipe... Just wondering, getting ready to but a Diesel Manor set...
Old Feb 20, 2007 | 12:31 PM
FN74's Avatar
FN74
I did the clamp method and that little ceramic washer broke, leaving a small exhaust leak at that spot. If you can get to it, I would recomend the drill and tap method.
Old Feb 20, 2007 | 12:34 PM
Ford_dad's Avatar
Ford_dad
Yea i was thinking it would be a better seal doing the drill and tap method... But sometime with a diesel you never know...
Old Feb 20, 2007 | 12:46 PM
hambonz's Avatar
hambonz
I would go with drilling and tapping the manifold. There has been alot of post on here about it. It just comes down to you on whatever you feel comfortable in doing. If you tap the manifold, go slow and keep it straight. Good luck
Old Feb 20, 2007 | 06:53 PM
afastone's Avatar
afastone
Yeah tapping the manifold sounds a lot worse than it really is, the metal is really not that hard so it's pretty easy to tap. Dieselmanor directions are very good follow them and you will have no problems. Good Luck
