Disc Brake Upgrades
Old Feb 19, 2007 | 08:00 PM
twobitranch's Avatar
twobitranch
Disc Brake Upgrades
I am looking for good ideas on disc brake upgrades for my 1978 F250 Crewcab. I pull a large horse trailer regularly and am needing to upgrade brakes all around. Any suggestions or good experiences? Thanks
Old Feb 19, 2007 | 08:16 PM
scottie2hottie's Avatar
scottie2hottie
Dana 60 (your rear axle) disc brake kits are pretty readily available. check ebay.
Old Feb 20, 2007 | 09:51 AM
1977f250's Avatar
1977f250
there is a realy good therad on here for dana 60 disk brakes. I have bookmarked but dont know how to send it to you. It was titled 77 Ford F250 4X4- Dand 60 disk brake conv. It was in his gallery I dont know his screen name but it says crated by Grant Blevins. Great delails on how he did his and was realy cheep. Check it out if you can search for it.
Old Feb 20, 2007 | 01:33 PM
Mil1ion's Avatar
Mil1ion
copy the url of that thread and post it as link.
Keep tech info on the site
Old Feb 20, 2007 | 07:50 PM
twobitranch
I would also like to upgrade the front brakes as I go. Any suggestions? I have found a couple of conversion kits on internet. Anyone have any experience with this one?
http://www.tsmmfg.com/2660.htm
Old Feb 21, 2007 | 09:36 AM
1977f250's Avatar
1977f250
https://www.ford-trucks.com/user_gal...&albumid=18312
Hope this works!
Old Feb 21, 2007 | 01:22 PM
FordTrucksKickGM's Avatar
FordTrucksKickGM
Will 16" wheels work with the disc brake conversion?
Old Feb 21, 2007 | 01:55 PM
1977f250's Avatar
1977f250
Go here Greatlakeoffroad.com and look to the right for the article on dana70 good right up on how to do it
Old Feb 28, 2007 | 10:18 AM
DosMas's Avatar
DosMas
The great lake brackets are the best looking brackets and fit quite well. Purchase the rotors and calipers and hoses at your local parts supplier, easier. Just know that the (front calipers from a 3/4 ton) 78 and earlier chebby use a 7/16-20 banjo bolt, and the 79 and later chebby use the 10mm x 1.5 banjo bolt. Most of the short SUS hose kits to put on the end of you hard lines have the 10mm banjo's, so you would need the 79 and later calipers. FYI- cause I learned the hard way.
Make sure you get the proportioning valve for the rear line. Otherwise your stock distribution block sends the new rear calipers too much pressure. I was told not to use the e-brake calipers as they are too much trouble. Go with the std calipers and when you get a chance put an e-brake on the transfer case. Rotor on the drive shaft, bolt mechanical caliper to the transfer case.
Make sure you position the new calipers and brackets so the bleeders face up, they do you no good facing down (physics).
