I'm taking my 55 F-100 with a 1980 Aspen front end to get it ajusted.What are the exact specs for ajusting the front end. I'm not sure my garage here in Norway knows exactly what measurements to use.Thanks Erik
Caster Range 1 1/4+ to 3 3/4+ Preferred 2 1/2 + or - 1
Camber Range -1 /4 to 1 1/4+ Preferred +1/2 + or - 1/2
Toe in 1/8 + or - 1/16
Hopefully this makes it through the language barrier. + or - means "plus or minus" Specs are obviously just a starting point for your Effie. The caster angle is the most touchy. It has to be positive or you won't like your truck much.
