Sponsored by: Real Truck
switched accessory wire location
Old Feb 19, 2007 | 12:28 PM
250HUV's Avatar
250HUV
Smile switched accessory wire location
Hey all,
I have a 2007 PSD CC that I'm installing heated seated and I'm looking for a switched accessory wire that I can tap into. Any suggestions? The wire loom under the door sill is very accessible but anywhere will do.
Thanks,
250HUV
Old Feb 19, 2007 | 12:52 PM
Lonewolftx's Avatar
Lonewolftx
Arrow Try This . . .
There is a switched customer access wire (10 amp) under the dash for your use depending on how much power you need. It is above the drivers side hump behind the driver glove box, or up fitter swtichs. You could use an upfitter switch as well if you have the.
