Got through to customer support, camera can work up to two hours continously and 19 feet distance. Thanks for the comeback firesoutmatt, looks like a run to Wally.
A deep cycle is designed to be fully charged and discharged almost to zero. A regular car or truck battery doesn't like that kind of treatment over the long haul.
A Marine battery is not enough description to say. Marine battery just means it is built to survive the pounding that you get in a boat.
There are regular starting marine batteries and those designed to be deep discharged.
The Marine battery whatever type it is will work better than a car battery. If it is also Deep Discharge so much the better.
