engine swap 351w or 460
Old Feb 18, 2007 | 10:06 PM
trucker56's Avatar
trucker56
ok i need some advice i have a f350 sc with a tired 351m or 400 4sp 4x4 transfer case i'm not sure what it is i was wondering what everyone thinks replacing it with a 351w efi mtr or a 460 has anyone done the 351w swap with efi the truck will see mostly hwy miles some light towing and ocassionly mud
Old Feb 18, 2007 | 11:54 PM
Torque1st's Avatar
Torque1st
Posting Legend
Check with the engine swap forum. Unless you are very experienced with Ford automotive electrical systems an EFI 351W is probably not a wise choice. The 460 will take some work also since it was not a factory option some feel due to drivetrain capacity/breakage. Drop in a replacement 400.
Old Feb 19, 2007 | 12:50 AM
Mil1ion's Avatar
Mil1ion
Remember computer controlled vehicles are specially set up to operate only in the vehicles they were installed in.
You would have to revamp a lot of things to go to EFI .....now if you went TBI ..that's different.
Old Feb 19, 2007 | 05:45 AM
Stratus's Avatar
Stratus
Nothing wrong with a nicely built 400, you can even add aluminum heads and TBI to it if you want. I have the same truck and went with a 460 since I got the finnished short block for only $600.00.
A new 400 would be an easy bolt in and cost much less.
Old Feb 19, 2007 | 02:45 PM
trucker56's Avatar
trucker56
ok thanks who make aluminum heads for the 400 ? is there anyway to raise the compression on this motor i've search and haven't been able to find anything more than he stock pistions and thanks againi'll probably stay with the 400 then any suggestions for the cam intake and headers whats a good combo
Old Feb 19, 2007 | 02:48 PM
Mil1ion's Avatar
Mil1ion
Flat top pistons
You know there is a 400 performance enhancement write up in the FTE article section
