1960 Headlight switch I used.
Old Feb 18, 2007 | 06:16 PM
bememe's Avatar
bememe
Thumbs up 1960 Headlight switch I used.
For you 57-60 guys, I recently purchased a Painless headlight switch #80151. I'm using an EZ wire harness and didn't want the original style switch with fuse block and all. This switch seems to be pretty good qaulity wise and can be modified to use original bezel. You will need your original bezel and the threaded retainer from your old switch. The threaded retainer needs to be ground down to remove existing threads plus some. Then rethread it for 3/8 fine threads. It will now go into the bezel, through the dash and thread into switch. Looks original except for aluminum ****.
Fastback460
18
May 14, 2014 04:23 AM
BlueOvalRage
Jan 5, 2012 12:20 AM
Jaaaaaaackman
Feb 24, 2008 07:26 PM
fatfenders
Apr 28, 2002 07:27 PM
