1978 - 1996 Big Bronco
Rough idle
Old Oct 31, 2002 | 02:45 PM
yosemite's Avatar
yosemite
Rough idle
I'd be interested in the same for the 88 351 EFI.
Mine runs in idle about 500-600rpm. It's the surging that it a problem, and it doesn't happen all the time. Surges more when in drive or reverse. Sometimes in park.
Old Oct 31, 2002 | 03:17 PM
mike0454's Avatar
mike0454
Rough idle
[updated:LAST EDITED ON 31-Oct-02 AT 04:22 PM (EST)]need to know if its auto or stick
Old Oct 31, 2002 | 04:01 PM
yosemite's Avatar
yosemite
Rough idle
auto w/overdrive 88 351 EFI
Old Oct 31, 2002 | 05:04 PM
mike0454's Avatar
mike0454
Rough idle
1988 5.8 diconnect idle solenoid.run eng at 1800rpm for 60 sec.put trans in drive rpm should be 575 if not adjust trim screw.reconnect idle connetor.star eng and let stablize for 2min then goose eng and let it return to idle.
Old Oct 31, 2002 | 07:35 PM
greystreak92's Avatar
greystreak92
Rough idle
Ok, how about the '92? Is the procedure the same and are the rpms the same as the 88? At this point I'll try anything to get this problem rectified.
Old Nov 4, 2002 | 11:58 AM
petem's Avatar
petem
Rough idle
Mike-sorry I didn't clarify. '92 Bronco with 5.0 with automatic transmission. Idle reset instructions would be great.
Old Nov 4, 2002 | 04:32 PM
mike0454's Avatar
mike0454
Rough idle
my mitchell repair info only covers 1986-90 i am going to contact them and try to get later model info
