auto trans help needed asap
Old Feb 18, 2007 | 01:43 AM
medicbearusaf's Avatar
medicbearusaf
Finally got my truck back from the shop after blowing the front trans seal was fine for the first 30 miles.. then it would occasionally rev up like it was in neutral did it a few times. so id throw it in neutral and pop back into drive no big deal.... Well didnt do it again for a few days 170 miles total later after gettin it back Reverse works just fine... But in drive if i rev it up to about 3k it starts to move slowly (kinda like if it was a manual and you were holdin the clutch in part ways and giving its gas so its not fully engaged) welll i could eventually get it up to 40mph and the truck would start to shake like it was trying to completely engage but couldnt... i know its been throwing a high (input or output) trans range sensor code for sometime now... and i remember the shop mentioning somethin about that when i picked it up...
trans fluid checked out ok didnt smell anything or see anything... havent been able to run a scan its at the shop till monday mornin any ideas?
Old Feb 18, 2007 | 05:23 AM
tjc transport's Avatar
tjc transport
i ain't rite
well, if it was me, i would call the shop that just got done tearing the trans apart, and tell them "you did something wrong. i am sitting on the side of route such and such, the trans died, and you need to send a wrecker to get it, and fix it so it drove like it did before you did the front seal"
