1978 - 1996 Big Bronco
Timing Chain question
Old Nov 5, 2002 | 08:08 AM
fcarruth's Avatar
fcarruth
For someone that does valve cover gaskets and a few other minor repairs, how hard would it be for me to replace the timing chain and sprokets on my 89 Bronco w/302 and 230,000 miles ? Also what are the needed tools and what kind of improvement will I see ?
Thanks again for all of your help,
Frank
1989 Bronco w/302
230,000 miles
Old Nov 5, 2002 | 12:54 PM
adelyser's Avatar
adelyser
It's not that hard, just time consuming as you have to take a lot of stuff off to get to the timing chain. To replace the timing chain, you have to remove the fan, fan clutch, water pump, A/C compressor (just loosen it), and the bracket for the A/C compressor. Then remove the crank pulley and timing cover, swap the timing set, and put it all back together.
Old Nov 5, 2002 | 03:48 PM
steve83's Avatar
steve83
You also have to be ABS0LUTELY CERTAIN that you have the engine @ #1 TDC on the compression stroke before you remove the gearset, because the replacement has to go back on EXACTLY that way, or your timing (valve AND ignition) will be off & the engine either won't run, or will be VERY weak.
Old Nov 6, 2002 | 07:19 AM
fcarruth's Avatar
fcarruth
Thanks much. I may give it a try in the next few weekends.
Frank
1989 Bronco w/302
230,000 miles
Old Nov 6, 2002 | 07:24 AM
PigFarmer's Avatar
PigFarmer
