E4od Rebuild
Old Feb 17, 2007 | 09:57 PM
warlock-jim's Avatar
warlock-jim
E4od Rebuild
TORQUE BLEW UP TOOK TO TRANS SHOP INSTALLED NICE NEW EVERYTHING. COOLER ,TORQUE ,VALVEBODY $1200.00 . THEY TOLD ME TO DISCONECT ALL BATTERY CABLES AND TO CLEAR ALL CODES BY HOLDING DRIVER SIDE CABLES TOGEATHER FOR 15 SEC. AND PRESS BRAKE PEDAL DOWN AT SAME TIME AND TURN LITE SWITCH TO DRAIN ALL POWER FROM COMPUTER. NOW MY TRANS ONLY WORKS IN O.D . AND 2nd AND REVERSE ? TRY TO SAY MY TRUCK IS THE PROBLEM. TOLD THEM IT WORKED GREAT. EXCEPT FOR TORQE WENT OUT. NOW I SAY IT IS THE TRANS. OR SOMETHING THEY DID. 1993 F350 DUALLY . 7.3 LTRE, TOTAL REBUILD OR ?????
Old Feb 18, 2007 | 11:06 AM
Ben-jamin's Avatar
Ben-jamin
you trans is controlled with a pcm on the truck whitch gets it's info from various sensors on the vehicle and you will need a diognostic tool to read them-not just a code reader. One of the sensors may be giving false info tha the pcm. can't use but if the info isn't "out of range" it may not set a code. Did you make sure all the connectors are fully seated? does the tach work? does the speedo work?is it completly full of fluid? I think it holds about 12-13 qts.
Old Feb 18, 2007 | 02:31 PM
warlock-jim
shop said sensors are all connected, tach works, speedo works,trans actually holds 17.5 qts. and is full. i think trans is out of sinc some where shop said tool was at other shop and will call monday after scanner is back.and problerm is solved i am look for some advise before hand, thanks jim
Old Feb 18, 2007 | 03:29 PM
PLC7.3's Avatar
PLC7.3
Sounds like your in Limp mode a safety net for the trans........don't drive it.
Did your tach and speedo work flawlessly.........
Did they reset the FIPL/TPS.......
Old Feb 18, 2007 | 03:39 PM
PLC7.3's Avatar
PLC7.3
Mercon fluid capacities E4OD
4x2.....14 liters/15.7qts
4x4.....15.3 liters/16.2 quarts
Add .3 liter/quart for extra cooler.
Old Feb 18, 2007 | 03:47 PM
PLC7.3's Avatar
PLC7.3
I can't seem to be able to edit my posts sorry for 3 in a row........
Check your fluid level on level ground..... there are 2 check areas on the stick one for cold and cross hatched area for hot........ too much fluid will foam up and cause erratic pressure control problems....... and probably limp mode. It may even be overflowing out the vent on top of the trans.........
Old Feb 18, 2007 | 06:26 PM
warlock-jim
no leaks anywhere ,tach and speedo worked fine . i guess when they reset everything it will work fine? i hope. i dont no what the FIPL/TPS is though.? i dont no anything about the e4od . i drag race on the weekends and pull a enclosed trailer around. i was wanting to put a manual trans in it until i was told i would have to change the wire harnes in the truck is that true ? i can pick everything up for it for 1350.00 (except wire harnes) pedal,flywheel,clutch ,preasure plate, driveshaft,slave cylender,5 speed manual, GREAT DEAL i think but not if wire harnes needs changed..
Old Feb 18, 2007 | 07:36 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Not much needs changed on the wiring harness.
The manual tranny has a clutch mounted start interlock under the dash, the plug is there on your truck.
The E4OD has a start interlock on the transmission shifter.
Moving the jumper from one location to the other should be about it for wiring changes required.
Old Feb 18, 2007 | 08:35 PM
warlock-jim
if i do all that will the engine run properly?i was told that it would not. correct me if i am wrong but e4od computer sensor would only make the automatic shift, has nothen to do with manual trans.i would sooner have manual than auto. for pulling purposes only sounds pretty easy now. but i dont no anything about this except what i read from here. this forum is just awsome
myakkacracka
13
Jun 16, 2016 11:33 AM
myakkacracka
Mar 17, 2014 07:35 AM
351Cleveland C4
The Next Generation
23
Sep 23, 2013 06:00 PM
boazjames
Jul 1, 2004 09:55 AM
