1978 - 1996 Big Bronco
Very Irratic Speedometer
Old Nov 5, 2002 | 08:02 AM
fcarruth's Avatar
fcarruth
I have had so much luck with this forum. After my speedometer had been fluctuating for a month or so, I finally found the culprit. It was the large 17 tooth gear at the end of the cable located in the transfer case. Took about 15 minutes and cost less than $15.
Thanks again guys and maybe this may help a few of you down the road.
Frank
1989 Bronco
230,000 miles
All Original
Gets better everyday !!
Old Nov 5, 2002 | 03:42 PM
steve83's Avatar
steve83
Beware: the blue spiral gear that drives the one you bought may not be far behind it! The drive gear should only be about $8 and the driven $7.50, but you have to get a pair that will work together & give you the right speed IF YOU'VE CHANGED TIRE SIZE. The cable wears out, too, and will cause the needle to jump.
All that is why I converted my '83 to use a '92-97 PSOM. The only moving part is the NEEDLE, and I can reset it with the buttons on the face!
Old Nov 6, 2002 | 12:57 PM
fcarruth's Avatar
fcarruth
What is a PSOM if you don't mind me asking a stupid question ?
Old Nov 6, 2002 | 06:58 PM
steve83's Avatar
steve83
Programmable Speedometer Odometer Module - the electronic speedo used on '92-96 F-series & Broncos, and some E-series & Aerostars.
Check it out:
http://www.webphotos.com/list_photos.asp?mi=3&smi=1&a=13217
http://bbs.off-road.com/ubbthreads/showflat.php?Cat=&Board=offroadfordbroncolate&Numb er=898100&page=0&view=expanded&sb=5&o=&fpart=
Old Nov 6, 2002 | 08:54 PM
steve83's Avatar
steve83
