Modular V10 (6.8l)
starting problem
Old Feb 17, 2007 | 07:05 PM
mammothsun's Avatar
mammothsun
Question starting problem
I have a class C motor home, 2000 V10 with 30K miles. Been sitting for a few weeks..fully charged battery. Tried to start and starter spun rapidly with no resistance (i.e...like no compression). Was OK when put away. Any ideas on what this could be ?? Timing belt doesn't seem likely in this new an engine ??
Bendix not engaging ?
What else could cause this. It just doesn't have that cranking, trying to start feel. No cough or sputter
Any thoughts are appreciated
Thanks,
John
Old Feb 18, 2007 | 04:49 PM
Bdox's Avatar
Bdox
Do you mean that the engine is turning and just not firing?
If so, try just turning the ignition to full on position and leave it for fifteen seconds before cranking. It may be that you fuel pressure bled down while sitting.
Old Feb 18, 2007 | 07:04 PM
mammothsun's Avatar
mammothsun
Went back today where RV is stored with someone and yes the engine is turning. That eliminates starter as problem. Thanks for that idea. I will try it tomorrow. If that doesn't work it may be pump or some sensor or ??
Problem is local Ford dealer won't work on a small class C RV even though it is basically a 450
Old Feb 18, 2007 | 07:18 PM
super 6.8's Avatar
super 6.8
Make sure the inertia switch has not been thrown. You never know and it would be worth checking. You will get no fuel until it is reset.
Just a thought and it would be a very cheap fix.
Old Feb 19, 2007 | 12:47 AM
mammothsun's Avatar
mammothsun
Good thought. Where is it ?
John
Old Feb 19, 2007 | 04:06 PM
Big Orn's Avatar
Big Orn
How much pressure have you got at the fuel rail - or do you have a good amount of pressure at the fuel rail? Are you sure that the engine is getting fuel? Can you hear the fuel pump running when you turn on the key? You can check the pressure at the Schroeder valve that located on the fuel rail. It looks like a tire valve.
Also, try depressing the accel pedal about halfway to make sure the IAC valve isn't bad.
Old Feb 27, 2007 | 05:28 PM
mammothsun's Avatar
mammothsun
Was the fuel pump
Bad fuel pump. $275 for new pump and fuel filter and 4 hours labor at $100/hour.
Thanks for all the input
Old Feb 28, 2007 | 02:42 PM
Big Orn's Avatar
Big Orn
Thanks for the update!
And congrats on getting her back in shape!
