Sponsored by: Real Truck
front rotor dragging
Old Feb 17, 2007 | 01:26 PM
mcjones44us's Avatar
mcjones44us
Hi guys,
So far this mod is a two-messager. Generally I can tell how well my upgrades are going by how many requests for help I post.
I just installed new powerslot rotors and hawk pads on the front of my yr 2000 X. Went out and did the bedding in procedure. Toward the end they say to do two moderately hard stops from 60 to 10mph. Did that and was pulling to the left badly.
Went home, and noticed that I smell something really hot coming from the passenger side front rotor. It's *really* hot, smells some, but not smoking.
I pulled off both front wheels to compare. The passenger side appears a little scorched. Besides maybe having to buy a new passenger side rotor, what do you think could cause a rotor to drag like that?
I carefully compared both sides and my install looks the same. The only thing different is that one of the little springs that stick into the pad backing plate was dislodged on my passenger side. Surely that spring missing couldn't result in that kind of heat, could it? I appreciate any help!!
Mike
Old Feb 17, 2007 | 02:10 PM
DCSpecial's Avatar
DCSpecial
Did you lube up the caliper slide pins when you did the install?
IF the slide pins are dry...the caliper will stick
The springs between the pads do push the pads out.
Old Feb 17, 2007 | 02:30 PM
mcjones44us
I sure did clean and lube the slide pins and their bores... hmmm. Thanks for the suggestion.
Mike
Old Feb 17, 2007 | 05:52 PM
mcjones44us
Well, unfortunately the dislodged spring wasn't the problem. Went back out to re-test and still gets way hot.
Anybody else have any other advice? I'm thinking about pulling the new rotor off the hot side and putting my old stock rotor back on to see if that gets hot. If it does, maybe I damaged the caliper. Crap.
