Moved from the 6.0L section. You should find a better answer here from the guys. In my own opinion I would check the tires and rims for balance or damage.
Is it just when going over tracks etc...? If you put heavier coil springs up front it will greatly help it out. Mine did. You can get factory heavier duty coil springs direct from Ford for about $70 a pair. It takes all of about an hour to change them also.
Hi!I have a Ford F350,2006,10 000 MG.A problem is front and shake.Can you halp me!
This is a known problem in 2005 and up super duties. Take it to the dealer for repair. There is a technical service bulletin on this. You can do a search on this site for more details.
My 2005 F350 dually work truck started at about 15K miles. I took it in when it became bad, at 30K mile. The service advisor told me they re-torqued all the front end fasteners and replaced the steering stabilizer. Whatever they did, it fixed it.
I had the same problem in my 06 F250 V10 and I did the same thing as sbrennan007 did as well as install a Ranch Hand grill gaurd, the main reason for the bigger springs. And it cured my dangerous unwilling lane changes after hitting pot holes and cement breaks in the road.
