1978 - 1996 Big Bronco
Engine Mods, questions, estimations.....
Old Nov 9, 2002 | 09:53 PM
gruveb's Avatar
gruveb
[updated:LAST EDITED ON 09-Nov-02 AT 11:12 PM (EST)]I have an 83 Bronco. I've owned it for about a year, but used it for work mostly. Now it has become a toy. I want to beef it up a little bit and since there are minor things that need to be done mechanically, I figure now is as good of a time as any to upgrade.
I'd like to focus on adding low to midrange power.
I have a 351 small block backed by a C6.
I'm gonna switch to a stock four barrel intake from an 87 (I think) F-250 and a holley 600. The rest is speculation right now:
So I'll be feeding the air/fuel mixture through 600 cfms of Holley into some GT-40 Ford heads, and out through some long tube 2 1/2 Hedmans and into some dual 2 1/2" tubes through some Flowmaster 80 series mufflers and exiting before the back tires.
What kind of improvement would I be getting? What type of numbers would I be looking at?
I doubt I'd do a cam swap, if I did, it would be something very mild. (If I did go for a cam swap, how would this do?
Small Ford: 351W, 290/300 degrees duration, hydraulic camshaft
Advertised duration: 290 intake/300 exhaust
Duration at .050 in. cam lift: 214 intake/224 exhaust
Gross valve lift: .472 in. intake/.496 in. exhaust
Lobe separation: 107 degrees intake/117 degrees exhaust
Peak horsepower rpm: 4,500
Peak torque rpm: 3,000
RPM range: 3,000-6,500
Those Motorsport guys live, eat, and sleep Ford. This camshaft with the 290 degree intake and 300 degree exhaust duration builds performance in the 3,000-6,500 rpm range.)
One last question, what type of horsepower and torque do I get stock?
Feeding my 9 mile a gallon habit.
Old Nov 9, 2002 | 10:26 PM
mrwizard's Avatar
mrwizard
If you're looking for low to midrange power, that cam's not the way to go. A 3000-6500 RPM powerband might be good for a lightweight car with a manual tranny, but not for a Bronco. I had Ford Motorsport's equivalent to Edelbrock's Performer cam in my '85 with the 351. Although it was no race car due to the 3.55 gears and 33" tires, I could definately tell a difference over the stock engine. Plus, I never had any vacuum problems often associated with bigger cams.
Old Nov 10, 2002 | 06:26 PM
gruveb's Avatar
gruveb
That cam peaks at 3000 rpm for torque and produces about 330 footpounds of torque at 2000 rpm.
On another message board I asked to have the numbers run on my mock buildup to see what I'd be looking at. Here's what Desk Top Dyno showed:
http://www.thirdgen.org/techbb2/showthread.php?s=&postid=979873#post979873
I'm gonna run the numbers on a different cam though, specifically designed for trucks. I picked the cam I did because it was relatively mild. Here's another option.
204 intake duration/216 exhaust.
456 intake lift/ 484 exhaust lift.
Old Nov 10, 2002 | 10:04 PM
bronco cam's Avatar
bronco cam
