Help!! Power Seat Not working
Old Feb 16, 2007 | 05:04 PM
Dokeytchs's Avatar
Dokeytchs
I have '02 Excursion Limited 7.3 PSD and the driver power seat is not working. I move the button on the side and nothing up, down, front, back, etc. The memory portion doesn't work either. I took off the switch and tried it on the passenger seat and it worked. There is power going to the seat motor. Any suggestions on what it might be? Is there a relay in the switch? Where can I get parts?
Old Feb 16, 2007 | 06:09 PM
twisted289's Avatar
twisted289
You have power to the seat motor? Is there power to the seat motor only when pushing the buttons or always power to the seat motor? If so Your seat motor may be fried, or a relay. There could be a seperate relay for each seat. Im sure someone with more experience in seats will chime in.
Old Feb 16, 2007 | 07:01 PM
Dokeytchs's Avatar
Dokeytchs
There is power coming from the truck to the motor is what I checked.
Old Feb 17, 2007 | 09:15 AM
96ozarker's Avatar
96ozarker
I have had this happen to my '02. I found that the connector under the seat just needed to be wiggled, maybe a little corrosion.
Old Feb 19, 2007 | 09:17 AM
Dokeytchs's Avatar
Dokeytchs
Is there a relay for the power seats?
