Quick Question
Old Feb 16, 2007 | 07:00 AM
guitarnik's Avatar
guitarnik
Talking Quick Question
where is the starter on a 91 f-150 with a 302 windsor?
Old Feb 16, 2007 | 11:32 AM
mtflat's Avatar
mtflat
Same place you'll find it on any other 289/302/5.0 - passenger side, under the exhaust manifold, behind the tire. You'll need to get down on the ground behind the tire, roll under and wiggle forward. Hit your head on the crossmember and look up. It's right there Should be two 9/16" bolts holding it to the bell housing along with a 7/16" nut (1/2"?) on the power wire. Of course you've already disconnected the battery, right?
