ford truck problem
Old Feb 15, 2007 | 07:10 PM
remmers's Avatar
remmers
ford truck problem
Ok it has been along time since i posted on here, but i just bought a 1990 f-250 4 x 4 with a 302 and a aod trans (auto) The problem i am having is when it is idiling it runs "great" and when i first take off it is hell on wheels, when i get up to speed around 40 or so and i go to punch it (to pass some one) it feels and acts like i am towing a 20 ton trailer, it just takes for ever to pass, the trans doesnt slip, the rear end is good. I am thinking that the cats are clogged, what do you guys thinks
Thanks for the help
Old Feb 15, 2007 | 07:24 PM
Redcat Diesel's Avatar
Redcat Diesel
If it sounds like compressed air leaking when you punch the pedal it's a good sign the cat is plugged.I've also seen mufflers collapse internally and act the same way.
Old Feb 15, 2007 | 09:16 PM
Conanski's Avatar
Conanski
Well, that's not a lot of motor for a big truck, so don't expect it to accelerate like a modern sedan. If it turns out you don't have a clogged exhaust or intake air filter, then maybe you are expecting too much.
Old Feb 16, 2007 | 08:54 AM
lostin90s's Avatar
lostin90s
No 4x4 auto truck is super at passing. BUT my F150 4x4 sc lb with maf 302 E40d passes just fine . It proforms just as well as my 92 F150 351 truck with out load. I'd check the cat . If it is supper peppy on low end check gearing if geared low you might be wound out RPM in passing . What the tach say
I run a F250 that we pull trailers with its geared low enough that in passing it is like putting on breaks. Good luck on fix.
Old Feb 16, 2007 | 10:44 AM
kell104's Avatar
kell104
Check the cats like you suggested, and change your fuel filter. My first guess would be your cats are plugged, that sounds exactly like how a freind's truck acted when they were plugged, it would idle just fine, but at a certain RPM the motor just couldn't push thru them any more.
Does your trans downshift when you punch it? Possibly you need a TV cable adjustment.
Old Feb 16, 2007 | 11:37 AM
92F150Flare's Avatar
92F150Flare
I definitely agree with the fuel filter, sounds like it's starving for gas. I've never seen or had a clogged cat but I know they happen.
Good Luck
Old Feb 16, 2007 | 12:22 PM
95Ford4x4's Avatar
95Ford4x4
what about revving the motor in neutral?? if it doesn't bog down while revving it up while sitting still, i would say your tranny needs some help. first step would be to check the adjustment on the tv cable, then i would drop the pan and change filter out.
