Sponsored by: Real Truck
Tires
Old Feb 15, 2007 | 05:42 PM
02F250XLT's Avatar
02F250XLT
Tires
i am planning on buying some new tires soon and the optional size for my truck is a 265/75SR16 i want to go bigger. Dunn tire says i can do a 315/75SR16 this is on a 2002 F250 and i am planning on dooing BFG all terrain
Old Feb 15, 2007 | 06:20 PM
redford's Avatar
redford
FTE Leadership Emeritus
On stock rims?
Old Feb 15, 2007 | 07:51 PM
metalman1320's Avatar
metalman1320
Stock wheels? Stock suspension? Tell us more.....
Old Feb 15, 2007 | 07:55 PM
UGA33's Avatar
UGA33
You can run 315's without a lift. May scrub on sharp turns though
Old Feb 16, 2007 | 06:33 AM
02F250XLT's Avatar
02F250XLT
stock suspension. but i am thinking about going up to like an 18 inch wheel if i have to. if i dont than yes the stock wheels
Old Feb 16, 2007 | 06:48 AM
metalman1320
This is based on my experience only, but there was no way I could have gotten 315's under my truck stock. It had 285's on it when I bought it w/ no problems. I think the 305's would have rubbed. They're the same height, just a little wider.
It took a 2.5" leveling kit and trimming of the lower plastic valance to fit 315's on my truck. I've heard lots of guys on here say it will work w/ no lift, but on mine, no chance. Every truck is different.
And the wheel DIAMETER makes no difference. The overall height of the tire is unchanged. Now the WIDTH and the OFFSET will make a difference as to rubbing or not.
Also I have 315's on 7" OEM wheels. It's not "recommended", but I hope it's only a temporary situation in my case. They do cause my tires to rub the leaf spring at full lock to the right occasionally. I've experienced no other negative side affects. Just keep em rotated.
Linemo
13
Dec 24, 2009 02:29 PM
FirstTry
Appearance & Dress-Up
Apr 2, 2006 09:52 PM
54 gene
New York Chapter
Sep 1, 2004 10:29 PM
mcdev
Nite, Nascar & Other Limited Edition Ford Trucks
Jun 7, 2001 11:14 AM
