I need some help for a fellow Greaser.
Old 02-21-2007, 02:48 PM
FN74's Avatar
FN74
FN74 is offline
Guess maybe I should mention my credentials also. This is Jason from Vegistroke/DFA. Deffinately need to get a fuel pressure reading above all else.
Old 02-22-2007, 06:19 PM
Frank Stahl's Avatar
Frank Stahl
Frank Stahl is offline
Thanks FN47, if I need new injectors what do you recommend.
I don't have any mods to my truck, I would like to get better milage.
Am I best off taking it in to a dealer to get them tested?
Thanks Frank
Old 02-23-2007, 04:49 PM
Frank Stahl
I used my supertunner to pull codes.
1) P0478
2) P0470
3) P1211
whats up with that?
what do I do next?
thanks Frank
Old 02-27-2007, 10:16 AM
ponch37300's Avatar
ponch37300
ponch37300 is offline
1) P0478
2) P0470
3) P1211
whats up with that?
what do I do next?
thanks Frank
P0478 is exhaust pressure control valve high input, i believe i got this code when my exhaust back pressure sensor tube was clogged, i got two codes, cleaned the tube and sensor and codes went away.
P0470 is exhaust back pressure sensor circuit malfunction, i believe this was the other code i got till i cleaned my ebps.
P1211 is ICP not controllable, above or below desired, i believe this is from your tuner and is normal with tuned trucks.
I just got back from week long vacation so my brain is kinda out of it but saw nobody else answered so thought i would give it a shot, if nothing else it will bumb this to help you out. Hope you get things worked out.
Old 02-27-2007, 04:24 PM
FN74's Avatar
FN74
FN74 is offline
Ponch is correct on the codes. Two are caused by a plugged backpressure sensor tube or sensor which comes out right by the Water pump, at the front of the motor, and the 1211 is infamous for most trucks with tuners, just means that your HPOP can't maintain the pressure the computer wants. Does not indicate anything broke. If you remove the tune back to stock and still get the 1211, then you need to look into it more.
About the only way to detect a shot injecotr is if the motor is running so poorly that it is detected in the balance test. But for that you will need an actual diagnostics tool such as the AutoEnginuity that can perform the test. There are a few ways you can go with your injectors depending on your ability. You can simply order up a set of rebuilt injectors from a variety of places such as Swamps Diesel and replace them yourself, or you can order rebuild kits from DIY injectors, I wouldn't worry about upgrading injectors either, your HPOP isn't strong enough to max out the stock ones. If you don't mind being down for a bit, Jonothan at Swamps will analyze your stock injectors and give you a full report on them at a reasonable price, just to make certain of the root cause. Etching is caused by a caustic, pitting usually caused by water, and scratches caused by poor filtering. Either or all fo those will contribute to the condition it sounds like you are having, as well as a few other possibilities, still centered on the injector.
Old 02-27-2007, 05:12 PM
Frank Stahl
Would I need to replace all the injectors or only a couple.
Sorry if this is a dimb question, I just don't know to much about this.
Thanks Frank
Old 02-27-2007, 05:17 PM
Hotwheelbill's Avatar
Hotwheelbill
Hotwheelbill is offline
Frank, I had to chime in here and say that I am glad to see all the help you are getting here, great people here!!
Jason, I am about 18,000 mile from calling you. Thanks.
Old 02-27-2007, 05:22 PM
Frank Stahl
Yes there are alot of great people in here.
Thanks again, Hotwheelbill, for posting and get me going on this great site.
I learned a lot of great info, tips and just good reading.
Frank
Old 02-27-2007, 05:25 PM
FN74's Avatar
FN74
FN74 is offline
Frank- You really should replace them all. There are several reasons for this, but basically if this was caused by fuel, one way or another, than likely all of them are at least slightly damaged. If one injector simply craps out, then that is one thing, but I don't believe that to be the case here.
And HotWheel- If you drive anything like I do, you will contacting me in about 3 months.....
Old 02-27-2007, 05:31 PM
Frank Stahl
How long can I keep driving like this, It still runs great on veggie.
I have been driving like this for 4 months already, I won't mess anything else up will I?
Frank
Old 02-27-2007, 05:49 PM
ponch37300's Avatar
ponch37300
Frank, i just sent you a pm before i read this. I live in appleton and have autoenginuity which can test you injectors for you. I have never used it for this so i will have to do some homework but if anyone can tell us how to do this i would be glad to help you out.
Old 02-27-2007, 05:51 PM
FN74's Avatar
FN74
FN74 is offline
That is hard to say. Chances are that No, you won't mess anything up so long as the injectors are not overfueling or leaking. I would do a blackstone Oil report to make sure that all is well in the bottom end. That will also tell you if you have any fuel in the oil from overfueling. Just make sure you still shut down and startup on diesel to avoid any coking issues.
  #28
Old 02-27-2007, 05:59 PM
Frank Stahl
Thanks I will be going on vacation the end of March and Then I will get it fixed.
All I really need is 1 more month.
Frank
  #29
Old 02-27-2007, 07:54 PM
Uzumati's Avatar
Uzumati
Uzumati is offline
Ponch KOEO and do a BUZZ test and KOER and do the CCT. Also you can monitor "Rotational Velocity Change %" for each cylinder in live data.
  #30
Old 02-28-2007, 06:55 AM
ponch37300's Avatar
ponch37300
Thanks Alan. Hopefully i can help him out and save him a few bucks.
Quick Reply: I need some help for a fellow Greaser.
