Brake Light Voltage
Old Feb 15, 2007 | 09:02 AM
huskiemobileman's Avatar
huskiemobileman
Brake Light Voltage
I just replace my brake lights on my '94 E350 with some LEDs, and for some reason when the ignition is turned on, I get about 8-9 volts to the brake lights without applying the brakes. This activates the LEDs but is not enough voltage to illuminate a normal bulb.
Is this normal for a Econoline? Any remedy for this? Thanks!
Old Feb 15, 2007 | 03:44 PM
packlet's Avatar
packlet
that's not right. check your wiring and the switch on the brake pedal.
Old Feb 17, 2007 | 10:16 AM
cocot's Avatar
cocot
Also, try running a new ground to the bulb.
