General Automotive Discussion
Escort Starting Issues...
Old Feb 15, 2007 | 07:17 AM
tcbofade's Avatar
tcbofade
All right, I know this is Ford TRUCK Enthusiasts, but my truck is doing fine at the moment. My car, however, is making me nuts.
I'm having a starting issue that I cannot resolve. Battery was new two months ago. Alternator was new within the last year. Both were tested by two parts stores yesterday and passed just loverly.
Sometimes it starts...sometimes it won't. Quick jumpstart, and it fires right up.
As it is all kinds of monkey butt cold out here, I was advised to go outside and start the car at lunch time...so I've been doing that for the last week or so with decent results...not yesterday tho. Car fired right up in the morning...(it sits in a semi heated garage at night...)...drove it to work where it sat til 10 am. I was out on break, and it fired right up...I let it run for 5-10 minutes, shut it off, went back inside...went out at 2 pm, car wouldn't start. Went out at 3:30 pm (quittin time) car wouldn't start.
Got a buddy to jump start me, drove to the parts stores for the above mentioned tests...
Battery's good, alternators good, and I don't want to just throw money at it. Any ideas?
Oh yeah...93 Ford Escort 1.9L with a 5 speed...you don't want to know the miles on it!
Old Feb 15, 2007 | 08:28 AM
modar's Avatar
modar
sounds like a connection problem. have you tried the wiggle the wires test?
Old Feb 15, 2007 | 09:33 AM
weeds's Avatar
weeds
My truck was having the same startup kind of problems. One night, I was looking under the hood trying to see if maybe the battery was the problem, and I could see arcing across the distributor. Tune-up fixed it right up.
Old Feb 15, 2007 | 10:27 AM
tcbofade's Avatar
tcbofade
I don't have a distributor...and the ignition module seems OK. No visible arcing. Wiggle the wires test? Would that be battery cables? No, I haven't tried that one yet...it does seem to be temperature sensitive, so it may well be a connection somewhere, I'm just not sure of where to look.
Old Feb 15, 2007 | 10:48 AM
Mil1ion's Avatar
Mil1ion
Check for corroded primary circuit ignition wire connectors.
These play havoc with start /no start situations
Old Feb 15, 2007 | 02:32 PM
Torque1st's Avatar
Torque1st
Posting Legend
Does the engine turn over or does it just not fire?
Old Feb 15, 2007 | 04:12 PM
tcbofade's Avatar
tcbofade
Nope...today I had no problem. But when it won't start, it won't even try. As I turn the key through the on position, the blower/radio and all that stuff come on. When I put the key all the way to the start position...I get absolutely nothing. Accessories go off, and the engine does not even try to turn over...not even try.
Apply jumper cables, and the thing fires right up. As I mentioned above, the battery and alternator are good, and I'm just confused.
Old Feb 17, 2007 | 01:15 PM
Lazy K's Avatar
Lazy K
You have a bad battery connection. Remove both battery wires from battery, clean connections on battery and wires well, spray everything including top of battery with WD40 and reconnect wires to battery.
